DallasSteve
May 15, 2023Nomad
Propane Connection Leaks
I bought a new Jayco travel trailer and it has new propane tanks. It's gotten warmer here so I'm not using propane lately; I cook with an electric stove top and I use electric for my fridge and water heater. The electric is free where I am right now and I like free.
The other day I was checking my propane gauge and it was green, which is good, but I noticed a slight odor of propane in the area. I thought maybe the connections leak a little bit of propane as a normal thing. So I closed the propane tanks at the top just to save any that is leaking. Last night we got some rain so things are a little wet outside. I decided to open one of the tanks because it's getting a little cooler. When I did I saw a little bubble form and pop under the cap that says "Do Not Remove Cap". That sort of confirms what I suspected, that the connections aren't perfect.
Is this any cause for concern or is it in fact normal that the connections will have a little bit of leakage because like me they aren't perfect? I don't smell any propane inside the trailer.
![](https://i.imgur.com/keUfygQl.jpg)
