- Cup_fanExplorer
searfoss wrote:
I made the wheel chocks. I also bought a quick wrench at sears. The wrench made tightening down the chocks faster. The wrench was $7.99 I had the 4X4 and bought the rod, washers and nuts. I put about $15.00 and hour into making them.
I did the same thing, cheap and easy to make. Works great. - searfossExplorerI made the wheel chocks. I also bought a quick wrench at sears. The wrench made tightening down the chocks faster. The wrench was $7.99 I had the 4X4 and bought the rod, washers and nuts. I put about $15.00 and hour into making them.
- BlatzExplorerThanks everyone. I appreciate your opinions
- crassterExplorer IIYes, definitely get these if you are going to be camping anywhere with any type of moderate grade. I would go with the real deal tandem over wedges.
- SoundGuyExplorer
Blatz wrote:
So using the lego style levelers on 2 wheels, what do people use for wheel chocks.
My preferred method is a set of adjustable BAL Standard Tire Locking Chocks -
Unfortunately the axle spread on our current trailer is a bit too narrow to fit the adjustable chocks so I instead use rubber chocks secured in place with hardwood spacers -
BAL X-Chocks are only intended to minimize suspension movement when walking around inside the camper, NOT to actually chock it - - bikendanExplorerThere are many tandem axle wheel chocks out there.
Just Google "tandem wheel chocks".
Wouldn't camp without them. - I have found that if I build the "block" platform a little larger than needed I can get the chocks in strong enough to hold. Basically the chock has to sit level.
- WalabyExplorer III do as others.. chock the off side (opposite lego levelers), and I also use X Chocks on both axles to stabilize the trailer.
Mike - WNYBobExplorerI love my Andersen Ultimate package, everything you need in one place.
You can also get Andersen Levelers separately.
Andersen Levelers - artmanExplorerI like the looks of these.
http://www.etrailer.com/Wheel-Chocks/Fastway/FA84-00-4840.html
I ended up with this
https://www.andersenhitches.com/Products/3600--ultimate-trailer-gear-duffel-bag.aspx
I still may get the first link for my tandem utility trailer.
About RV Newbies
4,026 PostsLatest Activity: Jun 15, 2017
