dpgllg
Apr 27, 2020Explorer
5th Wheel RV Cover removal and storage
This is the first year that I covered my 5th wheel to store it over the winter. I have a Goldline Cover by EEVELLE. The cover held up well and I only occasionally had to tighten the straps. I am only planning to cover over winter storage.
My question is what is the best way to store this cover? It comes with a duffle bag but it will take some work to get the cover folded enough to fit back inside although I will try.
My plan is to remove the cover and bring it home and lay it out in the yard to make sure that it is dry. I will also try to clean any dirt off if possible. Will automobile car wash be good to clean it?
What is the best way to safely remove the cover? I have a ladder attached to rear of the 5th wheel so I'm assuming that take it off from back to front. It went on front to back.
What will be the best way to fold it to have it fit in the bag AND be easily installed this fall?
Once in the bag should I put anything inside the bag such as mothballs or cedar blocks? I'm planning on keeping the bag in my basement which is finished clean and dry.
Any other removal or storage tips that you can share will be appreciated. I want to get as much life out of this cover as possible.
Thanks!
Dave
Thanks!
Dave
