ctilsie242
Jul 20, 2017Explorer II
A service for fixing RVs after the PDI
I saw this mentioned elsewhere, but when one buys a new rig, there is a company that would send a technician to the PDI, just to ensure all that can be fixed, will be. After the rig is signed for, the company will go in and spend time and deal with stuff, for example:
Anyone remember this company's name? It sounds like a useful service, especially for some brands of motorhomes which have a reasonable price, but fit/finish can definitely be improved. Their thing is to turn a somewhat decent motorhome into one that lasts a lot longer by fixing the manufacturer stuff from the get-go.
- Add a resonator to the Onan generator's exhaust.
- Add better shock mounts to the Onan as well.
- Add Fatmat/Dynamat/Hushmat to the doghouse so one can drive barefoot.
- Add an accumulator tank after the water pump, and/or just replace the water pump with a variable speed one.
- Add a solar charging system.
- If the disk is in the black/gray tank, which was cut out for the fittings, remove it.
- Ensure vents are secured, so they don't fall into the tanks.
- Go under the rig and add stainless steel wool and spray foam so critters go elsewhere.
- Reinforce areas that need it.
- Go up on the roof and hit everything that needs it with Dicor.
- Add backsplashes and other small items to make life easier.
