BeerCan
Aug 11, 2013Explorer
Synthetics make sense when you are going to do extend drains or live in severe climate areas. Otherwise a good dino oil will usually work fine. Severe climates are usually below zero and over 100 degrees Fahrenheit. I am generally against oil additives, the oil companies do a good job on their own.
You can lean a ton here at BITOG
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,104 PostsLatest Activity: Jan 24, 2025
