- Dog_TrainerExplorerI am on my second Chevy HHR. I just bought a 2011 with 50,000 miles on it. It is light and yet has the small suv feel lots of soace to get in and out of the door without hurting your back.
- JeffeExplorerOver the years we have towed a Suzuki Gran Vitara 4x4, Silverado 4dr/4x4, Grand Cherokee w/FT 4x4 and now a Ford 150 SuperCrew 4x4.
While they were/are all good tow vehicles the Grand Cherokee was the quickest, easiest and most practical because of it's medium size.
The F150 sets up easy and tows great; but, it might be too large for a lot of folks to tow. - BumpyroadExplorer
debandi wrote:
We have towed a Toyota Corolla, Jeep, Saturn Vue (easy tow), Ford Winstar with drive shaft disconnect, Honda CRV (easy to tow) and a Ford F150 with drive shaft disconnect.
Ford F150 is easy to tow and the drive shaft disconnect is easy to use.
The Winstar was good but the drive shaft disconnect was not east to use.
I had a drive shaft disconnect on my S10 pu and hated it. kept jumping out of mesh.
bumpy - debandiExplorerWe have towed a Toyota Corolla, Jeep, Saturn Vue (easy tow), Ford Winstar with drive shaft disconnect, Honda CRV (easy to tow) and a Ford F150 with drive shaft disconnect.
The Winstar was good but the drive shaft disconnect was not east to use. - dubdub07Explorer
Trackrig wrote:
Jeep Wranglers are very common. Easy to mount the base plates yourself, light weight and you can get off of the road some.
Bill
I would not say the JK is light weight. Mid 4K to 5K, depending on options.
WW - greenskeeperExplorereasy to tow, first was an 1998 Suzuki sidekick, no problem, next was a 2014 Dodge Dakota, now back to an 1998 Suzuki Sidekick...…………..
- Yellowboat_ExplorerI have a 2009 Saturn Vue. It is in the shop for the third time with transmission problems.
The first time was for wave plates. It was a known problem and was covered by GM under a ten year warranty for a known problem.
Second time was for speed sensor. I had them change the transmission computer chip at the tmsame time. This was not covered by GM.
Third time the gears have failed. While working on the wave plates a gear with a chipped tooth was found and replaced. So I'm guessing that GM has decided to cover the cost of repairs because of the previous wor
So I'xe been looking at the Ford Edge and Chevy Equinox. I noticed that the Edge is more expensive than the Equinox. And according to the towing guide the Equinox is easier to set up for towing. - BumpyroadExplorer
ttempleton wrote:
One vote Saturn Vue
I have a 2005 that is set up for towing. a good option.
bumpy - ttempletonExplorerOne vote Saturn Vue
- GjacExplorer IIIYou don't say what kind of MH you have, I am assuming it is a gas MH because you want a lighter tow vehicle. If that is the case I would look for one that you would want to use as your daily driver that is under 3000 lbs. There are a number of lighter compact cars like the Corolla, Elantra, Accent, Versa, Fiesta, Focus, Cruse, Sonic to name a few that can be towed. Start by checking the Dingy Towing guide for the year that you are interested in. Once you find a car that you like and the Dingy Towing Guide says it can be towed flat check with the owners manual at the dealers to verify. You will find more candidates for flat towing among older used cars.
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,110 PostsLatest Activity: Feb 16, 2025
