CA_Traveler
May 14, 2019Explorer III
The OP suspects multiple broken bolts and would need a KAP kit for each bolt. Does it exist?
Is the exhaust gasket still intact? I'm doubtful since red hot gasses could destroy it given the broken bolts. The exhaust manifold might be warped or need to be replaced. Sometimes there are updated parts to correct problems so this should be checked.
Hopefully the KAP solution will solve the problem.
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,106 PostsLatest Activity: Jan 26, 2025
