schlep1967
May 14, 2019Nomad
Unless you have a good deal of experience, this is a job for a professional. An easy out may work but it will most likely take a lot of heat on that area to have any chance. Those bolt heads broke off for a reason. The bolts are rusted into the holes and you are very likely to break off the easy out. Once that happens and you now have a hardened chunk of steel in the middle of the soft bolt you need to get drilled out, the professional is going to cost even more.
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,106 PostsLatest Activity: Jan 26, 2025
