Lightning55
Dec 01, 2019Explorer
Chucking....is it the trailer or the truck?
I know this has been discussed a thousand times and there are a thousand opinions about it's cause and remedy, but I can't continue to keep changing everything or buying new equipment in hopes of correcting the problem. I have to believe that it has something to do with relationship between the truck and trailer (weight, wheel base, axle-suspension location, or the like). I tow a 37' 5th wheel with a GMC 2500HD Duramax short bed. It was so bad over bumps that I dreaded towing this rig. I finally installed a Moryde pin box and it really did help. It doesn't fix the chucking but dampens it enough to make a difference but I can still feel it and I know it's hard on my equipment. I've changed pin weight, leveled the FW, installed Bilstein shocks and nothing has really changed anything except the rubber pinbox. It is so common with 5th wheels that I'm really surprised that some industry mechanical engineers haven't figured out what's really the cause of this condition. Maybe someone out there has some information that I haven't read about yet?
