marobrown's avatar
marobrown
Cracked skylight and water leak
Back in November we had a pretty good hail storm, had damage to my siding, as well as my wife’s and my daughters car. Checked out my camper pretty good, but apparently not good enough. I got a crack on the rim of my skylight, one across the very edge of a corner, another in the middle. I noticed it today when I went out so check on it as I usually do a few times during the winter. We have had a lot of rain the past 3 days and when I got to the bathroom I found a small puddle in the bathtub. I removed the inner cover, looks like the interior roof wood is pretty wet, but not soft. The upper roof wood has a few spots that are damp but not soaked.
My main question is what should I do first, call the insurance and start a claim or talk to the dealers service department?
Thanks in advance for any help
  • I just replaced mine last summer. It wasn't a bad job to do. As always the hard part was removing the old caulk.
  • I went back up the next day, and with the cool damp weather the silicone didn’t set well. Window and door was all I had. I ended up trapping that part of the roof since it was going to start another 3 day stretch of rain. Went out today after work and all the wood is dried and not soft. Hopefully I caught it in time and caught it early. Ordering a new skylight tonight.
  • If not too late, take several pictures of damage before covering with anything like eternabond or caulk that will be difficult to remove. The pictures will be useful when working with insurance company.
  • I did get up to the roof, cleaned and caulked the cracks, left the inner cover off. I was planning on resealing the roof this spring, so replacing the skylight at the same time would be nothing to do. I may let it dry out, see what it looks like. I did ask my insurance when I filed the claim on house and car and was told if anything came up I had 1 year from the storm to file a claim.
  • On my previous camper, we had all 3 crank-open roof vents and the skylight over the bathtub get beat-out by hail. I didn't catch it for a couple days, so things got pretty wet inside. Mine were not just cracked, they were broken clean out, with chunks missing from the plastic.
    I used massive amounts of duct tape to seal the gaping holes and keep the rest of the plastic from falling out. It held up pretty good. I avoided more leaking.
    The upper bunk was soaked, the kitchen area floor had a puddle in it, water standing in the bath tub, and the master bed was soaked. But!!! everything dried out. No damage to anything in the walls or anything else. The vent frames themselves are sealed to the roof so no water intrusion occurred in the roof or the walls. It just puddled and made stuff wet directly under the vents.
    Fast forward a few more hours and I called my local dealer and told them what happened. They gave me an estimate (over the phone) what it would cost to replace every roof vent and the skylight. Because I duck taped everything so well, I didn't need to be in a real rush for an immediate repair (which was good as we had more rain) later. I set up an appointment.
    I also had them to price me a knock-off Max Air vent cover for each vent and also replaced the fan in the vent in the bathroom as all the blades were so brittle, they broke off.
    At the scheduled time, I took the camper in. 24 hours later it was ready for pick-up and was less than $250 for everything! I considered putting a claim on my insurance, but I have a $500 deductible, so that just didn't make any sense.
    My suggestion, tape up the crack and fix up anywhere it's leaking. Let the camper dry out, and then simply replace the vent. It's a job that not so impossible the average Joe-Smuck can't do it, if you've got the time, effort, and energy, and not afraid to get on the roof.
    You always have the option to take it to a repair shop and have them fix it. Unless you've had previous water intrusion on your camper, a one-time leak thorugh the roof vent isn't going to seep into anything except what is directly under it. Now, if you've had problems with water intrusion in the past, then you may have a problem now. But getting wet once, drying out, and moving on won't mess anything up.
    If you put an insurance claim on it, you'll need to take it to a repair shop anyway. So why not have them check for water intrusion when you get the vent fixed. That's what I'd probably do.
  • The first thing I would do is caulk or cover the crack with a strip of Eternabond or something similar. Keep the water out ASAP.
    Depending on your deductible, it may be cheaper to replace the skylight yourself.
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,125 PostsLatest Activity: Apr 15, 2025
