- ontkenExplorerThanks for all your help. I found out the hard way not to turn the key to ON. The speedometer does turn there. As long as the key is turned to ACC the speedometer does not record miles towed.
Again thanks for all your replies. - EsoxLuciusExplorerAccording to the 2013 Chevy Spark owners manual the Chevy Spark with a manual transmission:
To dinghy tow the vehicle from the
front with all four wheels on the
ground:
1. Position the vehicle to tow and
then secure it to the towing
vehicle.
2. Shift the transmission to Neutral.
3. Turn the ignition to ACC/
ACCESSORY.
Never, exceed 70 mph.
Further, there are four positions for the ignition switch.
1. STOPPING THE ENGINE/LOCK/OFF
2. ACC/ACCESSORY
3. ON/RUN
4. START
In the ACC/ACCESSORY position the steering wheel unlocks and one can operate things like the radio and the windshield wipers when the engine is off. The battery could be drained with the key in the ACC/ACCESSORY position. Turning off and unplugging the 12 volt draws will reduce the amount of drain. If the odometer is illuminated in the ACC/ACCESSORY position it is possible that odometer will register miles. The salesman told me that the odometer will record miles with the key in the ACC/ACCESSORY position. I didn't believe him. - RoyBExplorer IIProbably you best bet is to setup the way you have to use and make a short run and record your before and after indicated mileage.
Probably depends on your make and model of the vehicle being towed.
Roy Ken - mowermechExplorerIf the IGNITION is on, chances are the odometer will register the miles towed.
If the switch is in the OFF, NOT LOCKED position (if it has such a position, some newer cars don't) the odometer probably will not register the miles towed.
If the switch has to be in the ACCESSORY (ACC) position, the odometer probably will not register the miles towed.
If it has a mechanical speedometer/odometer, the miles will register regardless of switch position. It is VERY unlikely that it has a mechanical speedometer. Nearly ALL vehicles today have an electronic one.
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,144 PostsLatest Activity: Jul 01, 2025
