Duo Pane
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report Inappropriate Content
Oct-19-2017 09:15 AM
What to do about moisture building up in window. I have read where you can drill holes to air out. Anyone tried this?
Templeton
2003 DP Holiday Rambler Endeavor 40 PST
Labels:
- Labels:
Seeking Advice
8 REPLIES 8
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Oct-20-2017 06:48 PM
If you are in the Mesa, Az area, contact APR-RV. Contact Michael! We had quite a few repaired while we were at APR-RV for our roof work.
Todd & Marianne
Miniature Schnauzer's - Sundai, Nellie & Maggie Mae
2007 Dodge Ram 3500, 6.7 Cummins, 6 speed manual, 3.73 ratio, 4x4
2004 Teton Grand Freedom, 39'
2007 Bigfoot 30MH26Sl
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Oct-19-2017 06:13 PM
If there is moisture between the panes your window has failed. There is no DIY fix.
Time for either a new window or contact one of the few companies that can rebuild them. I think there is one in Florida that is popular, I don't remember the name.
Build a life you don't need a vacation from.
2016 Silverado 3500HD DRW D/A 4x4
2018 Keystone Cougar 26RBS
2006 Weekend Warrior FK1900
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Oct-19-2017 04:04 PM
D.E.Bishop wrote:
It takes a very sp ecial drill bit and a heck of a lot of luck to bore a hole in tempered glass. In european countries where a lot of homes have dual pane windows, drilling a hole at the bottom of the window to vent the moisture is common but not inautomobile wiindows.
Theory is to drill through the spacer and seal between the 2 panes. Not to drill through the glass itself. As a note, tempered glass is not that hard. Break a glass bottle then take a sharp piece of it and you can easily scratch tempered glass. Tempering the glass does not make it hard. It allows the glass to flex without shattering and if it does break it doesn't break into a bunch of long sharp shards of glass. It breaks into smaller pieces that create a mess but aren't nearly as dangerous as untampered glass.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Oct-19-2017 03:56 PM
donn0128 wrote:
Dehumidifier works wonders. Difference between inside and outside temps, people breathing and living in and cooking in such a small area creates a lot of moisture that has to go someplace. Drilling weap holes is not the best solution, dehunmidifying the air is the correct solution.
Humidity inside or out should not cause condensation between the panes of glass. The seal has failed allowing outside or inside air between the 2 panes. Drilling a hole requires removing the glass and it's not a cure. Cure is to remove the window, separate the two panes and replacing the spacer/seal. Been there, done that. It can be a DIY job, I did ours, but it's not a simple task. There are companies that repair them.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Oct-19-2017 03:05 PM
"I travel not to go anywhere, but to go. I travel for travel's sake. The great affair is to go". R. L. Stevenson
David Bishop
2002 Winnebago Adventurer 32V
2009 GMC Canyon
Roadmaster 5000
BrakeBuddy Classic II
David Bishop
2009 GMC Canyon
Roadmaster 5000
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Oct-19-2017 01:39 PM
donn0128 wrote:I'm not sure high humidity is the cause of moisture between panes of glass. ON the glass, yes.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Oct-19-2017 11:54 AM
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Oct-19-2017 10:41 AM
Same question
