GA1dad's avatar
GA1dad
Electric brakes??
First off, my apologies if I posted this in the wrong section.
Can anyone offer a good reading or video source for electric brake adjustment basics? I admittedly know nothing about them, and have only piddled with adjustments up to this point,, but would really like to read some "best practices" on the subject.
  • Oh...suspect all advice on these freebie forums...it is worth the price paid... :B
    Meaning...so many insist that XYZ fixed their problem and is the end all
    for EVERYONE else...but...that depends on so much...like is their setup
    EXACTLY like others, etc
    Why the long thread...covers most areas and note that many of them
    over lap to mask the true root cause of whatever problem(s) trying to solve.
    Or use them as the end goal for the setup
    Suspect my comments too...just learn the general areas of this control
    system. Know their dials/knobs looking for the root cause of any issues
  • IMHO... :B
    There is no one best one size fits all, but found & continue to find that
    most who have helped are not adjusted well...and sometimes not correct
    First, the trailer brakes are normally not adjusted tight enough and
    suggest carrying an adjustment spoon no matter which brake controller.
    From OEM on board, highly integrated to after market.
    Check them at each stop and re-adjust them as needed.
    Wiring, first thing is to note that most trailer OEMs only provide a
    'just good enough' harness (wire gauge sizing), connectors and run them
    in series. Parallel (think spider) is best/better. Second, the harness(s)
    all the way back to the TV's controller needs to be in good order.
    The TV plug at the receiver some times has an El Cheapo that does NOT
    home in well and sometimes too much play to cause intermittent connections
    If after market, the TV brake pedal light switch must be adjusted so
    that just a tiny amount of foot pressure will turn on that switch.
    Plunger types (think door bell button) are tough and becomes intermittent
    if too close
    My GM OEM brake pedal switch is not adjustable and has one of the smallest
    switch points have found to date. Takes about 1/64" movement to turn
    on that switch and way before the MC piston even moves
    That has the trailer brakes turn on before the TV's turn on (leads the
    TV). This is has the whole setup act as one while braking
    The controller has two main adjustments and will only comment on them.
    The OEM IBC (integrated brake controller) sometimes has several more.
    Boost and gain.
    One is the min level pre-set and has to do with how the trailer brakes
    are sized, setup, work, etc. Think of it as if too low, there is no
    braking of significance by the trailer
    Other is the ramp the brake controller will follow once it is turned on
    Finally, all the above is factored by the sensor that the controller
    employs
    Some use the TV MC fluid PSI sensor. Some (most after market) uses
    an accelerometer to sense the rate of deceleration and will provide
    more power to the trailer brakes accordingly...ditto MC fluid PSI
    senses...the more PSI...the more power is sent to the trailer brakes
    This is why the trailer wiring MUST be top notch, as with poor wiring,
    all the power in the world sent back there will be lost to high resistance
    These are the basics, IMHO, and key to setting up the TV/Trailer to
    brake as 'one'...
  • Click the following link to download a copy of the Tekonsha Prodigy owners manual. It will give you about all the information you need. The information on adjusting is pretty generic so it doesn't matter if your controller is not a Prodigy.
    Barney
  • I'll bet there are internet videos for the Prodigy controller.
  • Thanks folks,, yes the electric controller was what I meant. Sorry for not being clear. Thanks Barney!
  • Take a look at this thread stuck at the top of the page. It will give adjustment procedure complete with pictures. (about 2/3 of the way down the page)
    If you are talking about adjusting your electric brake controller in the truck then this is the generally accepted procedure.
    1. Drive and apply the brakes several times to get them warmed up.
    2. Drive at 25mph and apply the hand controller as hard as it will go.
    3. If the brakes lock up, reduce the gain a bit and try again until you get just to the point before lockup.
    4. If the brakes will not lock up at maximum gain, do not despair. It is not unusual for electric brake to be unable to lock the wheels on pavement but should do it on sand or gravel. If you get a good strong tug then you should be good to go
    5. Keep trying to lock up the brakes with gain adjustments until you get the strongest pull back possible without the wheels locking up. Leave the controller at that point until braking performance diminishes then adjust the brakes and the controller again.
    Barney
  • This job is not hard, but nice to have an experienced helper the first time, or online sources like E-trailer have videos you can watch. It works best to have a brake adjusting tool, that has the right width and bend, even though some just use a flat screw driver.
    Jerry
  • Brake adjustments on drum brakes is pretty easy. First, go to any auto parts store and buy a brake spoon.
    Next, jack the wheel your going to adjust off the ground. Pup the rubber gromet at the bottom of the backing plate off. Using the spoon stsrt turning the star wheel until the brakes lock the wheel tight. Back off 3 to four clicks. Replace the plug and move to the next wheel.
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,110 PostsLatest Activity: Feb 17, 2025
