โMay-15-2016 07:52 PM
โMay-19-2016 11:21 AM
Jayco-noslide wrote:
My guess is that going down does not cancel up because the motor is still running and using some fuel?
โMay-19-2016 09:14 AM
โMay-19-2016 08:00 AM
โMay-16-2016 04:51 PM
โMay-16-2016 04:50 PM
โMay-16-2016 04:48 PM
โMay-16-2016 04:46 PM
lbrjet wrote:
You may have had favorable winds (or lack there of) on the trip. I can get 7 or 10 on the same route depending on the wind.
โMay-16-2016 10:59 AM
โMay-16-2016 09:48 AM
โMay-16-2016 08:16 AM
โMay-16-2016 08:07 AM
โMay-16-2016 06:14 AM
DrewE wrote:
Aerodynamics do make a big difference in power needed (and hence in fuel milage) at speed, as you've seen. Weight, in itself, is comparatively a non-factor for flat highway driving. For stop-and-go driving at low speeds, things tilt more in the opposite direction.
I don't know if it applies in your case, but the back end of the trailer makes at least as much of a difference in air resistance as the front end. A squared-off back introduces a lot of turbulence and air resistance; this is why practically all new cars have sloping backs, even if it makes for poorer back seat headroom or poorer trunk access or poorer rearward visibility.
โMay-16-2016 05:46 AM
