JaneNLee's avatar
JaneNLee
Falcon 2 hitch
Need help. How do you retract the arms that hook to the tow vehicle? Rv and truck has been removed, how do you get the bar to retract? Thank you
Mod Edit: Correct spelling of Falcon in the Subject title.
  • The Falcon 2 uses a release bar that is a separate part to release the arms. They are a bear to release tension while on the vehicle if you don't have the tool.
    *Edit, Video above has it all.
  • Please ignore this post, I will go to a rv dealer for help CU on the road
  • Can't help you except to move this to a better forum for the answer.
    You might want to edit your post to correct the name of the hitch. I believe it is supposed to be a Falcon 2 hitch.
    Good luck.:)
    Moved to Dinghy Towing forum from Towing.
    Barney
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,116 PostsLatest Activity: Mar 11, 2025
