LarryJM
Jun 06, 2015Explorer II
dodge guy wrote:
Personally I don`t care for the Equalizer hitch. it is really just a friction sway control. the better hitch would be a Dual Cam for it`s resistance to sway. even better for a Van with a large overhang would be the Hensley or Pro Pride. I don`t think you`ll ever get it to where you want because of the overhang on the van unless you step up to a better hitch.
I'm really not sure all that is correct. While not the ideal hitch the Equal-i-zer should perform just as well as the Dual Cam. I do agree the HA or Pro Pride would be best, but that is a lot more added wt. on the already apparantly maxed out receiver limits.
I can tell you that unless you have a good load in the Van the handling with larger TTs won't be as good as if you have plenty of dog for these larger tails.
Larry
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,102 PostsLatest Activity: Jan 18, 2025
