lholliday
Mar 20, 2018Explorer
Geeze:
Our Spark door locks are manual. We do not have electric door locks. We purchased the basic of all basic 2017 Chevy Spark cars. In fact, our biggest problem is forgetting to lock the doors and reminding the driver to unlock the passenger door for the passenger.
Our steering column never locked. I sent a question off to Corporate Chevrolet asking if the key in the ignition was really necessary and that I think people would be interested in the answer because there appeared to be a lot of people worried about draining their batteries. They responded with no answer and that we should follow the directions of the manual. Read below, I have more on this later....
j-d:
With Blue Ox, all we have to do is make sure that their Braking System is setup correctly and turn it on. We don't have to any pumping. Our problem went away when a wood block was added to the front of the base of the unit to keep it from tipping forward.
To anyone interested:
So Chevrolet's 2017 and 2018 Spark Bulletin recommends updating their manual. The new steps read:
To dinghy tow the vehicle from the front with all four wheels on the ground:
1. Position the vehicle to tow and then secure it to the vehicle.
2. Apply the parking brake.
3. Shift the transmission to Neutral.
4. Disconnect the negative battery cable at the battery. See "Negative Battery Cable Disconnection" following.
5. Cover the negative battery post with a non-conductive material to prevent any contact with the negative battery terminal.
6. Release the parking brake.
(Note: I'm not including the "Negative Battery Cable Disconnection" procedure to this feed.)
Our solution was to add a Battery Disconnect Switch. I also want to point out that we no longer put the key in the ignition while towing. I want to note that we keep the battery connected (turned on) to the car while initially setting up the Blue Ox Braking System. We want to be sure that there is no pressure on the brakes so we need to look for the brake lights. When this is validated, we disconnect the car battery. Lastly, we then have to turn the RV key to Accessory so that we power going to the BO Braking System. (Note: This means, every time you stop for gas, you're going to have to remember to go back to the car and turn on the BO Braking System when you start the RV again!)
j-d:
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,102 PostsLatest Activity: Jan 18, 2025
