โApr-07-2015 07:19 PM
โJul-25-2015 04:28 AM
Sandy & Shirley wrote:Like I said, you convinced yourself the Elite was not for you. I got mine several years ago, adjusted the cable once and threw away the worthless warning light. I and many others on this and other RV forums would use nothing else.az99 wrote:
Sounds like you convinced yourself against the Elite. Good Luck.
We were totally leaning toward the Elite and then read some other posts about it. The posts were not glowing and also not bad. Some liked it some did not. We were disappointed that the monitor in the Motor Home was wired and only gave you a single led to say the brakes are on or off. The problem was that it was connected to the Elite and only told you if the Elite was asking for brakes, if the proper slack was not in the cable connection you might not have brakes! There was also no way to make any kind of adjustments from the RV for things like sensativity. The adjustments were made by stopping, getting out, and adjusting the cable by hand. Also, our RV dealer and car dealer had never installed a cable controlled braking system.
The unit we chose uses a two way wireless monitor and adjustment system, and the RV dealer was very familiar with the installation process.
โJul-24-2015 07:36 PM
โJul-14-2015 02:02 PM
โJul-12-2015 05:25 AM
az99 wrote:
Take it to a Mom and Pop auto repair shop and get the Ready Brute Elite installed. $4,000 is CRAZY.
โJul-12-2015 04:47 AM
8handicap wrote:
WOW!
Does your tow bar have a ball joint(s) to allow for the drop? I have to use a 6" drop receiver on my Tiffin Open Road.
Ron
โJul-11-2015 10:04 AM
โJul-11-2015 08:50 AM
โJul-11-2015 08:05 AM
โJul-07-2015 11:16 PM
โJul-07-2015 04:43 PM
8handicap wrote:Don't know why but there are two small wires connected at neg bat terminal on my 2013 focus.Couple years back some one on another forum complained about fried transmissions on focus.He was disconnecting neg cable at fire wall.Ford says disconnect neg terminal.
Hilldude,
Not trying to be smart just confused. If the negative cable is disconnected, how can these two extra positive wires cause a problem? I do not see the two extra wires. Are they bound to the positive cable?
Ron
โJul-04-2015 11:29 AM
โJul-04-2015 09:03 AM
โJul-03-2015 02:37 PM
โJul-03-2015 12:27 PM
