SJ-Chris's avatar
SJ-Chris
May 05, 2023
Fresh water tank taking too long to fill...any suggestions?
I have a 2013 Coachman 210qb Leprechaun 23' Class C. I believe it has a 50 gallon fresh water tank.
The issue I am having is that it takes a VERY long time to fill up the fresh water tank. I have other RVs with similar sized fresh water tanks and they take a "normal" amount of time (5-10 minutes) to fill up the fresh water tank. But for some reason on this 23' RV it takes a very long time. 25-30 minutes or more. It is as if there is something restricting the flow into the tank. Or, could the tank be a closed system and perhaps the air in the tank has no way to escape during filling and therefore it creates a sort of back pressure to limit the amount of water that can enter? I can hear the water flowing. When the fresh water tank is nearly empty I can hear the water flowing in (splashing) when I turn on the hose. But it seems like once the fresh water tank gets to be 1/2 to 2/3rds of the way full the water flow into the fresh water tank is reduced to a trickle.
This RV uses the type of water fill connection where the water hose (when filling the fresh water tank) gets screwed into the connector on the side of the RV. (This is different from some of my other RVs that simply have a ~1.5" opening tube (with a cap) where you slide the hose into the pipe to fill it up). The connection point for the hose does have a screen, but when I have looked at it before it didn't look like it was blocked/clogged. I do have a simple water filter that connects to the end of the hose to filter the water going into the RV fresh water tank, and I have verified that the water easily flows through that filter (it isn't causing the flow restriction).
I haven't taken a close look yet or started taking things apart. Just thought I'd check here to see if anyone had any suggestions.
Thanks!
Chris
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,131 PostsLatest Activity: May 12, 2025
