Dick_B's avatar
Dick_B
gas line interferes with drain plug
I have a new Dometic Water heater model G6A-8E-SP,gas only with spark ignition. The gas line into the Heater is much inline with the socket needed to install/remove the drain plug. I can still do it with a channel locks but it is more difficult and will eventually round off the hex head.
Anyone had this problem and solved it?
I don't know how to add a photo.
I found something, not previously mentioned, that worked for me yesterday. It is CTA Tools, 2573, Low Profile 24 mm socket that was originally designed to remove oil filters, I think, but worked for me tightening up the drain plug once started by hand. It uses a 3/8 inch drive.
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,111 PostsLatest Activity: Feb 18, 2025
