eb145
Apr 24, 2017Explorer II
getting to zero degrees F in RV fridge.
It is amazing what can happen when you follow the manufacturers written installation instructions.
A couple months ago I spent a few hours and fixed the installation of the RV propane/electric fridge in the slide-out of my 5th wheel. I have the Norcold large 4-door 2118 model. This last week it actually reached zero degrees F in the freezer and was getting the refrigerated section down to near 32 degrees F on setting "7"... I had to reduce to "5".
My wife thought the fridge "wasn't working" because the fan wasn't blowing. The fan inside the fridge used to never stop running because the fridge never stopped running. Until I fixed the "chimney" in back, the fridge could never get cold enough. It just ran constantly.
I used to be able to get to 38 deg.F in the fridge section and 12 deg.F in the freezer section if it was not too hot outside and the sun didn't shine on the fridge.
The problems with the installation were all from the trailer manufacturer not following the installation instructions for the back side of the fridge. The back side is essentially a chimney that lets air move from the outdoor bottom air vent, across the coils and out the top vent. The clearances between the fridge and the "chimney walls" were wrong everywhere in the back of the fridge which let the air move all over the place but not where it needed to go (across the coils). I corrected them and what a difference.
Anyway I am happy now. DW is happy. My food is colder and the ice cream is finally hard.
It was a pain to work on the chimney from the outside through the two vent holes. But the effort was worth it for me.
Maybe Norcold should provide chimney kits to make their fridges work better for more of their customers. They must be losing a lot of their business to residential fridges because the RV manufacturers don't install them correctly.
Happy Camping
Ed
Happy Camping
Ed
