down_home
Nov 25, 2020Explorer II
I haven't used a Sureflow but in the years here, I think this is the first report of this problem. I thought freezing, but you ruled it out. Then the installation is wrong,in some way, or something is hitting it hard. I don't see a photo and installed which might tell a lot. On the Aqua flow four screws through four rubber vibration isolators, two hose quick connects and on quick connect 12v electrical plug is all there is. Only possible problem would be using a power driver to tighten the screws/bolts down but I think they are stepped on ours. The Sureflow is almost exactly or exactly the same as the Aqua Flow best I remember.
Ours is 55psi at 5.5 gallons a minute I think and it would break of its on accord quicker than the Sureflow you have of its own accord.
Have a Good Mobile Tech install the next one and look at the whole installation.
Water pumps are probably number two in the number of jobs they get called for right behind water heaters, and maybe number one.
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,115 PostsLatest Activity: Mar 04, 2025
