- mkirschNomad III kinda figured the tires rubbed and blew out on the road...
- Grit_dogTrailblazerMy initial response was not in consideration that this trailer may have had this issue just recently and on the side of the road en-route somewhere. Although not really specific as to it's situation and location.
IF it's actually stranded somewhere enroute then my first suggestion was totally not valid. - mkirschNomad IIIf it can be moved enough to get it off the road, it can be moved enough to get it on a lowboy. Over height/permit issues are the towing company's problem, and it's most certainly not their first rodeo. Most likely there is an exemption for "emergency" tows. Let them worry about it.
Portland Heavy Towing is the first result in google. I would start there.
They may be able to block and chain the axle and frame well enough to get the trailer where it needs to go without loading it.
It's been a couple of days. Certainly this trailer is not still sitting on the side of the road? - Bionic_ManExplorerI lost a wheel assembly on my 5er many years ago. I called around and found a tow service that had a semi and a lowboy trailer they used to move the trailer (and truck) to the nearest repair facility (which was about 60 miles away).
- Grit_dogTrailblazerAssuming it’s going to scrap (or a homeless encampment, lol) since repair wasn’t mentioned.
Can it be scrapped where it sits or nearby? That is likely the least expensive scenario.
Get a roll off of 2 and rent a mini excavator. Turn it into a dumpster full of Trash and a frame with wheels that can be cut up and scrapped or towed to a recycler.
Just a suggestion.
BTW a 5ver on a lowboy will likely be a permit req over height load. Not to mention trying to load a broke frame (or any) 5ver onto a trailer. No legit hauler in their right mind would take that load.
I’d think the same for a heavy dolly system. Possibly minus the over height issue. - Any access to the frame? I would be looking to bolt some steel plate to bring it together and just tow it to the shop. Or bring a welder out and finish it right there.
Any pictures?
Otherwise most commercial tow companies have the equipment or a partner that does. Could cost as much as the repair depending on the situation. - FulltimersExplorerMaybe find someone that can temporarily weld it enough so you can move it.
- JRscoobyExplorer IIWhere you going to tow it to?
Years back a company I hauled for had similar problem with office trailer. I showed up with my tool truck, fixed it on site.
Sure, I could of got it on/off the RGN, but still would need to fix. Likely saved them money.
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 09, 2026
