- RobWNYExplorerI don't have a bumper on my RV. That's why I will be using a hitch clamp and keeping the weight down. My receiver is only rated for 300 lbs. so with the weight of the cargo carrier, that leaves me with 150-200 lbs. max availability.
- wa8yxmExplorer IIII once added to a Horrible Freight one. But I was adding depth not width.
- BarabooBobExplorer IIIWhen I had my Class C, I had a carrier on the back pumper. I used ratchet straps from the end of the basket to the bumper on the C to eliminate wobble.
I had a truck tool box mounted on the carrier that blocked my tail lights so I added some crazy bright LED tail lights to the carrier. - JaxDadExplorer III
Dick_B wrote:
500 lbs on a hitch?
I routinely carry 275 - 350 pound aircraft engines on my custom made hitch carrier. I hardly even know it’s there. - SeonExplorer III fabricated my own carrier and welded two 2" square tubing underneath about 48" apart then used square U-bolts to clamp them on the TT 4" bumper. No side to side wobble.
- RobWNYExplorer
Ed_Gee wrote:
I'd think you'll get a LOT of side to side wobble on such a wide carrier...... be prepared for that.
I plan on using a hitch clamp which should eliminate that wobble. - RobWNYExplorer
Dick_B wrote:
500 lbs on a hitch?
I won't have more than 150-200 lbs on the carrier. - Dick_BExplorer500 lbs on a hitch?
- Ed_GeeExplorer III'd think you'll get a LOT of side to side wobble on such a wide carrier...... be prepared for that.
- JaxDadExplorer IIIeTrailer has one but IIRC it's a sort of DIY thing, frame only, you build the basket.
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,114 PostsLatest Activity: Feb 24, 2025
