Hot Water Heater Funny Issue
Rbertalotto
I'm parked at a friends house in Montana for a few days. I couldn't get my hot water heater to heat the water to the usual blistering degrees. I'd run the hot water to drain the tank down with fresh water entering and it wouldn't start. I checked voltages, connections, gas supply....everything was fine. Then I went into the bathroom and tuned on the COLD water and the water was very hot. Turns out the dark green, 100' hose from my friends house, laying in the hot sun, was heating the supply water to the hot water heater to just above the turn on thermostat setting. I was so relieved as I have 2600 miles to go to get home! This morning, upon turning on the hot water heater that wonderful, familiar "click" and "flame roar" was so welcomed! Hope this helps others that might find a similar situation.
RoyB
Dartmouth, MA
2021 RAM 2500 4X4 6.4L
2011 Forest River Grey Wolf Cherokee 19RR
520 w solar-200ah Renogy Li-Epever MPPT
14 REPLIES 14
wa8yxm
way2roll wrote:
And that is why it's not called a hot water heater. 😉
Thank you for that w2r.. I needed a good laugh and I totally missed it this morning.. So Thanks
And yes you have a point.
CabinetmakerII
Old-Biscuit wrote:
Water heater only heats COLD water initially...after heated it reheats Hot Water cause 110*F temp is considered HOT water
Therefore it is perfectly acceptable to refer to it as a Hot Water Heater
Otherwise....get over yourselves.
Perfectly acceptable to some... but not all!
Cabinetmaker
2021 DRV 39 DBRS3
2017 F-450 4X4, Riece 24K Hitch
2011 F-450 4X4, Companion 18K Hitch, Air Bags (Retired)
2012 Cyclone 3800, 5th Airborne Kingpin (Retired)
2018 Polairs 1000 XP Side by Side
Lynnmor
I would be more concerned with a dark green hose in the hot sun all day, that water must stink of plastic and is surely not a hose suitable for a drinking water system. If you must use an unsafe hose, at least run it off till fresh water flushes it out and then fill your tank and put the hose away.
Boon_Docker
We have a bunch of unemployed comedians and we can see why they are unemployed. :B
Old-Biscuit
wildtoad
I see an opportunity for someone to come up with a set of valves similar to the wh bypass ones to allow an external source of preheated water (by solar) to feed the cold water side of the wh. That way you could use it when there is ample sun and warmth. A side benefit is a greater supply of hot water.
Tom Wilds
Blythewood, SC
2015 Jeep Wrangler 2dr HT
wildtoad
Have a brother-in-law whom used to work for Lowe’s in the appliance department. He said anytime someone would ask to see their hot water heaters, he say something like… Sorry sir Lowe’s does not sell hot water heaters, but if you’d like to see an appliance that heats cold water they’re right this way under the water heater sign.
Tom Wilds
Blythewood, SC
CabinetmakerII
jdc1 wrote:
Why would anyone need a "hot water heater"?
My wife and I have had this discussion for years! Just cant get her to understand the "Water Heater" Is heating COLD water!
Cabinetmaker
2021 DRV 39 DBRS3
way2roll
Navigator II
Navigator II
Right.
coolmom42
That could be concerning, for sure. Glad you figured it out!
Single empty-nester in Middle TN, sometimes with a friend or grandchild on board
jdc1
2012Coleman
Imagine that - a hot water heater that wont heat hot water....
Experience without good judgment is worthless; good judgment without experience is still good judgment!
2018 RAM 3500 Big Horn CTD
2018 Grand Design Reflection 303RLS
Lwiddis
"Turns out the dark green, 100' hose from my friends house, laying in the hot sun, was heating the supply water to the hot water heater to just above the turn on thermostat setting."
Would have been the last thing I thought about!
way2roll
Navigator II
Navigator II
