- wa8yxmExplorer III
EnzoColorado wrote:
Got it off, turned out the inside lens pops off, then it's four screws to get the whole thing off, it's only screwed directly onto the ceiling, no box/hole or anything. Pretty cheap construction.
Glad you got it off and that's standard practice for 12 volt lights.
Check your marker/clearance lights
or (Depending on the model year) The tail lights on a car or Trailer or Semi Truck. - EnzoColoradoExplorer IIGot it off, turned out the inside lens pops off, then it's four screws to get the whole thing off, it's only screwed directly onto the ceiling, no box/hole or anything. Pretty cheap construction.
- bgumExplorerPull straight down on both sides of the trim ring.
- RedRollingRoadbExplorerIf they are like mine they are held in place by a spring that is about rat trap strong.
wildtoad wrote:
That looks like a standard can light. Have you tried pulling the decorative rim straight down using both hands?
I tried with a prying tool to pull down and it budged a little but otherwise didn't come loose. I didn't want to break something. - bukhrnExplorer IIIOK, guess i should have read the entire post, i see you have tried twisting it.
- bukhrnExplorer IIII don't have that type, but have you tried to twist that outer ring, maybe it screws off/on, try counter clockwise.
- wildtoadExplorer IIThat looks like a standard can light. Have you tried pulling the decorative rim straight down using both hands?
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,116 PostsLatest Activity: Mar 11, 2025
