leeper
May 29, 2016Explorer
Hydraulic Levelers
When I first started to use my levelers, I found out I could program them to automatic level. I then wonder how that worked when you went to different camping spots. At first I thought the leveling was done with bubble levels. I now think that they are programed for each one to go to a set position and not by levels. What good would that do if you go to a different camp ground all the time and not the same spot? Seems like you should be manual adjusting the levelers and not with the programed setting. What do others do?
