jaycocamprs
May 17, 2013Explorer
walker2413 wrote:
friend of mine said that there is a valve in the city water inlet that may be defective. I don't know how you would be able to identify that it is bad either.
Bill W
If the check valve at the inlet goes bad water will go out there. It's on the pressure (output) side of the pump, not the suction (inlelt) side. And I did see where you got your issue fixed.
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,116 PostsLatest Activity: Mar 11, 2025
