- nightshiftExplorerFrom Trojan's website: Many charge controllers have equalization settings that you can set to help ensure the health of your batteries. Equalize your batteries at least once per month for 2 to 4 hours, longer if your batteries have been consistently undercharged.
I had a Magnum 2012 inverter/charger installed. What a difference it made in my battery performance! - CavemanCharlieExplorer IIII thought it was "Snake Oil" too. But, I thought I would throw it out there.
- Triker33ExplorerI put one of these on my chassis & house batteries a couple years ago.
So I won't know if it works or not for a few years yet.
Power Pulse - westendExplorerIt contains magnesium and cadmium sulfates. They are both salts so may have adverse effects on plates within. Cadmium, is very toxic, also.
- Boon_DockerExplorer IIIThe only problem with using "Battery Equaliser" is that it makes the batteries really heavy. So you have to replace the sky hooks quite often and they are pricey.
- Hiker_01ExplorerWell, here's my $0.02. Realizing battery manufacturers are in the business of making money, if they could add a little bit of chemical (at very low cost to them) to a battery and improve the performance by 25+%, they would as then they could charge a lot more for the battery.
- pianotunaNomad III"snake oil" indeed. You can use epsom salts to extend life a bit--but by the time you need such "treatments", the battery is pretty much dead meat.
- Ed_GeeExplorer II
CavemanCharlie wrote:
I found this product listed in the link below. You are suppose to add it to your batteries to make them last longer. I am not going to use it. I don't need it. I just thought I would post it on here and get your opinions.
http://www.batteryequaliser.com/
I m quite dubious. 150 years ago they would call this, " snake oil ".
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,189 PostsLatest Activity: Mar 27, 2026
