- JimmyG_The_OneExplorer
AC = DC / 0.6360
Soooo...Probably not long.
- MNtundraRetNavigator
You would be better off with 2 6-volt batteries. Two group 27 12-volt batteries would give less time.
- CampinfanExplorer III
voodoo101 wrote:
Consider using a kill-a-watt meter from P3. Inexpensive and you can plug your fridge into it for a day or whatever duration you choose. It will give you actual power consumed. Go from there rather than guessing.
Sounds like great advice. Thank you. - lenrExplorer IIIMy residential fridge draws 1.3 amps, 120 volts, when running which is nowhere close to all the time. My battery monitor says my batteries are down to 55% in 8 hours when not plugged into shore power. However, driving down the road they only drop to 90% so I have to believe that the truck hot wire is supplying 80% of the fridge draw. No DC to DC converter is used, just a straight connection.
- ScottGNomadMost new residential fridges use between 100 and 300 watts* (22cu/ft) and while the vehicle is running it will be putting out 14+ volts so the 7 pin would need to provide somewhere between 7~25 amps.
*Momentary start up current not withstanding. - Chum_leeExplorer"Does anyone know how many amps are drawn by an inverter to convert to AC for a residential fridge. Can anyone tell me how to figure it out.
Look for the Manufacturers ID plate attached somewhere to your refrigerator. It will state the load in amps @ 120 volts. Convert that to watts. Watts = Volts X Amps. For example, if your refrigerator draws 6 amps @ 120 volts, the watts equal 6 X 120 = 720 watts actual load. Now add the power draw of your inverter (in addition to the energy required to run the frig) to convert from 12 to 120 volts. If you have a 1000 watt inverter, figure about 5%. So .05 X 1000 = 50 watts. Now add that to the actual load. 720 + 50 = 770 watts. Now convert to battery amps @ 12 volts. 770 / 12 = 64 amps. That's a lot, but it is not continuous. It's based on the duty cycle of your refrigerator.
64 amps @ 12 volts far exceeds what you could reasonably/reliably expect to run through a single pin on a standard 7 pin truck/trailer connector. Your residential refrigerator may draw less than 6 amps (@ 120 volts), but, if it's a high end model with all the bells and whistles, it could be considerably more.
Chum lee - voodoo101ExplorerConsider using a kill-a-watt meter from P3. Inexpensive and you can plug your fridge into it for a day or whatever duration you choose. It will give you actual power consumed. Go from there rather than guessing.
Campinfan wrote:
I did go buy a group 27 instead of the group 24 but now I am thinking I should have gotten the 6 volts or a second 12 volt but I am not sure another 12 volt will fit in the space.
One group 27 battery is not nearly enough capacity to run the fridge for more than a few hours.wanderingbob wrote:
I am just curious since we are on the subject , Two inverters , hooked up the same , one is 1,000 watts , the other is 2,000 watts , both on idle , nothing plugged in . Is the 2,000 watt machine drawing twice as much current as the 1,000 watt one ?
Every inverter will have a different no load draw. Looks at the specs of the two inverters in question so see what their no load draw is.- The amp draw from the batteries via the inverter is dependent on what the AC amp draw of the fridge is. Look at the specs of the fridge to get the amp draw.
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,111 PostsLatest Activity: Feb 18, 2025
