SailAndPaddle wrote:
The top of my TV's receiver is 17 3/4 inches above the ground. I'm buying a Jayco 26BHS which I'm told has a coupler height of 24". This is a 6 1/4" difference. I've read that the truck may settle up to 2" once the tongue weight is applied. If so, I'd need a hitch with a shank that will adjust 8 1/4 inches. I'm considering an Andersen hitch with a shank that only adjusts 8". Do you think I'll be close enough? My TV is a 2013, 2 wheel drive Sierra with 20" wheels. Thanks!
Welcome to the portal !
Do some home work before going much farther and note that the advice
here is free and advisers have no liability to you
Meaning there are dials/knobs/etc adjustments and that not knowing the
goal can cost you down the learning curve. Both in $$$ for parts to
even changing TV or TT to accomodate
Your " My TV is a 2013, 2 wheel drive Sierra with 20" wheels " has no
specifications.
Sierra's come in +6K GVWR, +7K GVWR, +8K GVWR, +9K GVWR and even
higher. They *ALL* come in 2 wheel drive. They *ALL* come with 20"
wheels, both standard for whatever package or optional.
A 1,000 lb trailer tongue might have the +6K GVWR Sierra squat so
much to have the front tires lift off the pavement...while the same
1,000 lb tongue on the 1 ton Dually not squat more than an inch...
Provide more specifics and not the 'dry' trailer weight, the 'dry'
tongue weight and the GVWR/RGAWR/FGAWR/GCWR of your Sierra.
