โOct-06-2015 09:07 PM
โOct-08-2015 07:27 PM
โOct-08-2015 07:15 AM
Terryallan wrote:
I don't know what type of Sway control you are using. however. Sway bar manufacturers suggest you loosen, or remove it in the rain, or other slick condition. They can cause the TV to go straight in a turn.
From the Reese sway control bar instructions
4. When towing during slippery conditions such as wet, icy, or snow-covered roads or on loose gravel, turn on/off handle (5)
counterclockwise until all tension is removed from unit. Failure to do so could prevent tow vehicle and trailer from turning properly.
I wonder if that could be adding to the "wiggle" feel?
โOct-08-2015 05:14 AM
thehippie wrote:dodge guy wrote:I'm using the last link.
Sounds like you have too much weight taken off the rear axle. maybe try taking off a link or 2!
โOct-07-2015 05:47 PM
โOct-07-2015 03:37 PM
Ron Gratz wrote:thanks, i'll try to schedule a trip to the scales.thehippie wrote:This photo from your post in a different thread shows the hitch head is adjusted for maximum rearward tilt.
I noticed since my tow vehicle is rear wheel drive, the rear wheels would 'wiggle' more when raining. So when raining, is it advisable not to use WD hitch so the tongue weight of travel trailer would push more on the tow vehicle's rear wheels and be more stable?
Depending on the number of chain links under tension, you might be removing too much load from the rear axle. If so, you should reduce the amount of load transfer.
But, as others have said, you should not eliminate load transfer completely.
A trip to the scales will tell you how much load is being transferred. You'll need to make three weighings:
1) TV front and rear axle loads with TT unhitched and WDH in the TV's receiver,
2) TV front and rear and TT axle loads with TT hitched but no WD applied,
3) TV front and rear and TT axle loads with TT hitched and with WD applied.
Passenger and cargo loading of the TV and TT should be the same for all three weighings.
Post the scales numbers and we can assist with interpretation.
Since you are using a friction bar sway control, you might need to apply slightly more steering input in low-traction conditions.
But, I would not expect the friction bar to cause the rear-end "wiggle".
Ron
โOct-07-2015 02:52 PM
โOct-07-2015 07:40 AM
โOct-07-2015 06:58 AM
โOct-07-2015 05:03 AM
โOct-07-2015 04:58 AM
โOct-07-2015 04:31 AM
โOct-07-2015 04:28 AM
โOct-07-2015 03:24 AM
โOct-06-2015 11:47 PM
