Jul-09-2018 06:36 PM
Dec-30-2018 12:12 PM
Dec-30-2018 11:26 AM
Dec-30-2018 09:34 AM
Jul-11-2018 04:42 PM
Jul-11-2018 02:15 PM
Jul-10-2018 02:31 PM
Jul-10-2018 01:52 PM
Jul-10-2018 12:03 PM
wadecool wrote:MFL wrote:
If you have the 5.3 V8, it should do the job. I'm sure you know that TT will put you right at truck's towing limit. You will likely add more than 500 lbs to trailer wt. You will need to have some water on board while traveling, I am thinking you'll add 1,000 lbs minimum to trailer for that length of trip.
Everyone has a different comfort zone, when it comes to towing. That camper appears to be a bunk house, and you don't say how many passengers will be going on the trip. Everyone/everything in the truck counts against the truck's GCVWR.
Anyway, when towing right to the vehicles limit, some will say it was a nightmare towing experience, and the next person say the tow went really well.
Jerry
It will be myself, wife, 11 year old daughter, and 2 medium size dogs. I planned on putting most of the gear in the truck bed. As far as water, I planned on keeping the tanks in camper empty and just bringing a couple gallons to carry in truck. We can get water as needed at Ye Olde Wal-Mart as needed on the way.
I'm good with going slow and taking our time, I just want to make sure I don't cause any damage to the truck on the trip.
Jul-10-2018 11:47 AM
Jul-10-2018 10:31 AM
mkirsch wrote:
Don't get obsessed with putting things in the truck, thinking that somehow preserves towing capacity! Every pound you put in the truck reduces your towing capacity by roughly 7 pounds.
I can pretty much guarantee that you don't have 1800lbs of payload capacity. Using real world weights you are closer to 1200lbs, and by the time you put your family and the trailer tongue on the truck it will mostly be used up, and your truck will look like a giant stepped on it.
You can tow seven times as much as you can haul. Anything that can go in the trailer should go in the trailer.
Jul-10-2018 10:26 AM
Jul-10-2018 07:17 AM
ppine wrote:
I had a Chevy PU once with a small block V-8 and 3.08 and it was a terrible tow rig, I used to tow a 2 horse trailer with it which is around 5,000 pounds loaded.
Jul-10-2018 07:15 AM
RTCastillo wrote:
First thing I'll look is the truck's operating manual. It should clearly state towing limits.
Jul-10-2018 07:04 AM
