Queen_s_Castle's avatar
Nov 09, 2019
Location of the voltage regulator needed
I'm attempting to locate the voltage regulator on a 2002 Coachmen Cross Country Elite. Anyone know where it can be found?
  • More specifically, it is a Cummins diesel. Does that change the answers? Thanks guys, for the responses.
  • Notify moderator function not working (again).
    A duplicate of this post in Class A section. Probably better there.
  • riggsp wrote:
    Most later model voltage regulators are built into the alternator.
    Actually, on most later model engines, the voltage regulation function is handled by the engine control computer. Whether a 2002 model did it that way, I couldn't say. Older model GM products did indeed use a regulator that was built in to the alternator, while Ford and Dodge vehicles still had separate voltage regulators. You could buy the GM regulator as a separate part if you were willing to disassemble the alternator to replace it. (I used to sell auto parts.)
    Bottom line to the original poster, you may not have a separate voltage regulator.
  • Most later model voltage regulators are built into the alternator.
