Son_of_Diablo's avatar
Jun 05, 2016
LP gas noises
I recently had my two 30 pound LP tanks filled on my 5th wheel. Since then whenever my refrigerator is operating on gas I can hear a chirping/whistling noise coming from one of the tanks outside. If I switch the auto valve to the other tank the noise stops. I checked to make sure the tank hand valve was fully open and that the hose connection was tight and there are no leaks.
Any ideas what the chirping noise is ?
  • Try shutting that cylinder, bleeding the pressure and opening it again slowly.
  • I had something similar start to happen. After some research here, I decided to replace the pigtail hose between the tank and the cutover valve. That solved my problem.
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,187 PostsLatest Activity: Mar 18, 2026
