CA_Traveler
Aug 15, 2016Explorer III
I can see where the black ground wire goes to a screw with a square housing. It's connected well, as are all the other wires.Those wires and fuses are part of the DC or battery electrical system and have nothing to do with the your AC shock. The AC portion is under the panel and there may be a junction box somewhere.
Now that you can post pictures which can help to understand what your saying I suggest you start from the beginning. AS SUGGESTED use the 3 light tester on the extension cord. If OK then use in on a rig plug with and without loads. What does it indicate?
We can go from there but need good input from you.
BTW Suggest you check the meter in the house with a good plug as it may be damaged when you used the wrong connections.
Also AC can be dangerous as your dog found out. You would be wise to get some help so that no one gets hurt.
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,115 PostsLatest Activity: Feb 27, 2025
