leeper's avatar
leeper
Metal Valve Stem Caps With Rubber "O" Ring
Seems that the rubber "O" ring seal on the inside of metal valve stem caps are getting inside of my valve stems. They end up in the inside the stem wall and around the out side of the stem needle valve. This stops air from being filled in the tire. Took the rubber "O" rings out and everything works find. The "O" rings are there to keep out water and dust. Anybody else come across this? The rubber caps do not have this "O" ring which is not needed.
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,115 PostsLatest Activity: Mar 04, 2025
