There are two kinds of main breakers used. One is the self resetting kind
The other had both a button and a lever.. I ... had issues understanding it the first time I saw one.
An automotive test light. this is a tool that looks like an ice pick with a light in the handle and a wire coming out the side of the handle.
Hook clip to battery negative touch tip to battery positive BRIGHT good. no light make sure the bulb is properly set (I often have to reset)
Move clip to any non painted metal frame part. Same. only now you are testing the battery negative cable (likely good) and connections and the attachment point (I say likely good cause jacks work)
Now move out along the battery positive lead. Every time you find a connection test.. You may have to move the ground clip as you go.
Retest last known GOOD point if you have to move the clip (Testing ground clip)
Broblem exists between BRIGHT and Dark.
You can also use a volt meter. But this is so much faster and easier to read.
