Keily's avatar
Keily
PD Power Transfer Switch Replacement
Good Morning
I need some advice, I have a 2014 Winnebago Adventurer. 2 days ago my transfer switch went bad, we had a power outage were staying, and I think it fried the transfer switch. I had no shoreline power when we camped the next day in a different park. When I went to the storage bin where the shore line cord was stored I could smell the odour of burnt electronics. I by passed the transfer switch and got power restored in the motorhome so we can continue our trip back home.
The park that we are in right now has an RV Repairman resident here and I was talking to him about it, and he seems to think the transfer switch has a 2 year warranty on it from Winnebago. Does anyone know if this is true? I tried to contact my dealer, and Winnebago about this yesterday, and neither one has bother to reply to my messages.
I checked with Progressive Dynamics and they only warranty for one year.
My other question I have is ,I have to get a new switch, so I was wondering if there is a better ,more reliable switch out there, and I should add that my motorhome has an automatic generator feature, the power goes off the generator comes on if it is set to auto, great feature if you have a pet, so with that feature do I have to buy a special transfer switch that needs to work with the auto gen feature?, or would any transfer switch work for my 50 Amp service.
It seems to me that on my last motorhome ,1999 Winnebago Chieftain the transfer switch was a TC something, and it worked flawlessly for 15 years.
Any help or suggestions would be greatly appreciated, BTW this is just one of many, many problems with this motorhome.
Thanks
Keily
  • Thanks for the info, I have ordered a new switch. It will be waiting for me when I return home.
  • Your power systems auto start monitor, is the special part
    Any 50 amp RV transfer switch will work
    Better.. Best ?
    IMO yes.. There is one brand that has mechanical interlock between the two relays and coils used in a 50 amp switch
    Quality 50 amps switch uses two separate relays one for shore one for generator
    When one is on the other can Not be engaged
    Even if you open it up and pushed it with a stick it could NOT engage
    Almost Impossible to create an accidental short circuit between generator and shore power
    If I can find it again I will post it
  • Winnebago only has a 1 year warranty. If there was a longer warranty, it would be with the transfer switch manufacturer. Looks like you are stuck buying and installing the switch.
  • Since I don't know what transfer switch you have, I don't know if there is a better, more reliable one out there. But, I can tell you this: Yes you need a "special" transfer switch to work with your generator. Actually, your generator isn't automatic at all. Your transfer switch is automatic, it controls your generator, tells it when to start and when to shut down. Well - technically it all works as a system .......... Ah forget it, Yes you need "special".
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,115 PostsLatest Activity: Mar 04, 2025
