smhnevada
Jul 01, 2013Explorer
Pressure Pro sensor problem, maybe
I have a 2004 Winnebago Sunrise, 32 foot Class A. I seem to have bad tire karma. Always had trouble with tire pressure on the rig. Last week had new tires put on, pressured up and re-installed the Pressure Pro sensors. The next day one of the tires had dropped from 85 psi to 69 psi. Same problem I have had many, many times before on different tires with the same Pressure Pro sensors. Swapped out the extender. Next day same problem. The only thing that is now common to all the tire pressure problems is the Pressure Pro sensor. Different tires, new extenders, valve stem checked for leaks. I have read all the great reviews on Pressure Pro systems on this site but am wondering has anyone had a problem with pressure pro sensors leaking air.
Thanks in advance.
Thanks in advance.
