Herd_Fan's avatar
Herd_Fan
ProFlex flexible RV sealant
It seems like most people (including my dealer) suggest using this product for all general non-roof sealing jobs (along diamond plate edge, outlets, trim pieces, etc..
I know ProFlex says it can be applied over itself. Not knowing what type caulk was originally used on my fiberglass trailer, should I remove all of the old first, or will this produce adhere ok over most types as long as you clean it good first?
  • Proflex is the best sealant to use for vertical surfaces. On the roof Dicor is better. Both can be used with surface prepping with a solvent and they recommend using Naptha which is not sold in my state but I found that the substitute product sold by Home Depot works equally well.
    Klean-Strip Industrial Maintenance Coating Thinner
  • I found some Proflex that was clear. Haven't found it to attract dirt any more than any other sealant.
  • I apply it over the existing caulk. I clean the area with soap and water and have never had an issue with it not sticking. Use some liquid dish washing soap diluted in water and put it on your fingers to smooth out the caulk. Otherwise it sticks to your fingers.
  • jdog wrote:
    Why can you not use it for roof sealing?
    Personally I have found that over time it will pull away from a TPO roof. However TPO is uncommom; people call it a rubber roof but it's more like polyethylene, which almost nothing sticks to. Most "rubber" roofs are EDPM, and I would guess that ProFlex would stick to EDPM.
    All that said, Dicor lap sealant would be my choice for a roof. Its style of bulk buildup seems better suited to roof sealing jobs.
  • dalmationlovers wrote:
    I use Proflex on all seams of my last 3 rv's. I would scrap the old caulking off first and put new on. I use the liquid for roof seams and the caulking in a tube for side seams. I have not found it to attack any more dirt then any other caulking. On the roof seams I usually apply a coat over the other each spring. I clean the surface first and then apply a coat. I have the luxury of having the MH in a garage so I can work in any weather, but the liquid works best when applied at above 60 degrees.
    dalmationlovers:
    Are/were all these roof surfaces fiberglass that you used the Proflex on?
    LeRoy
  • I use Proflex on all seams of my last 3 rv's. I would scrap the old caulking off first and put new on. I use the liquid for roof seams and the caulking in a tube for side seams. I have not found it to attack any more dirt then any other caulking. On the roof seams I usually apply a coat over the other each spring. I clean the surface first and then apply a coat. I have the luxury of having the MH in a garage so I can work in any weather, but the liquid works best when applied at above 60 degrees.
  • If you don't have silicone on there now, you can most likely go over it with ProFlex. What I do is use a rag dampened with lacquer thinner to clear the scum off the old caulk first. OTOH, any of the old caulk that comes off easily, you might as well remove.
  • My experiences with Pro-Flex have been that it is hard to work with and attracts dirt like a giant sponge after it is applied. I would suggest that you call your manufacturer and find out what they use and do the same. And, I did clean off the old when I used Pro-Flex.
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,130 PostsLatest Activity: May 11, 2025
