Question on using "Great Stuff" foam sealant
NanciL
Has anyone here used Great Stuff foam sealant?
I have an open space under my shower where I can look down and see the ground and I am going to use it to seal it.
I have read all the directions on the can, but I can't figure out how to stop the flow once it is started, and it doesn't say how.
Once the straw is screwed into the tube the foam is supposed to start flowing, but how do you stop it?
Jack L
Jack & Nanci
21 REPLIES 21
Chuck_thehammer
after is sets... you can CUT it with a sharp knife...
and can use a wood rasp/file to shape it... primer and paint if needed.
as stated.. go EASY.. it expands a lot. and can damage ...
wear gloves.. it's difficult to remove from Hands .... or anything...
gbopp
Do you have the can of Great Stuff that is designed for a dispensing gun?
As mentioned above, the regular cans have a trigger.
I have found that if you leave the dispensing tube screwed into the can, you can leave it dry and later clean the tube. Then you can use the remaining foam for other projects. I have used leftover foam several weeks after the initial use. YMMV
WEAR DISPOSABLE GLOVES when working with the foam. It's very difficult to remove from your skin unless removed quickly after contact.
Dave_H_M
whoah, great tip there Lynmore.
Lynnmor
If you don't want the ugly yellow color, use landscape foam. It's the same stuff in a dark gray.
Yeti_plus
The straw screws onto the trigger. You have to operate the trigger to make the foam flow.
It expands like crazy so be careful that you don't put too much in as it can break or move things that get in its way. Since you can see the ground through the hole you should block it off underneath. duct tape or cardboard to cover the hole should work.
And as others have said, throw out the can when you are done because in a day you can't use it again.
2014 Chevrolet 3500 CC 4X4 Duramax, Tork Lift Tiedowns, TorkLift Fastguns, Superhitch and supertruss
2009 Jayco 213 SOLD
2008 Bigfoot 25C9.4
Halmfamily
You can purchase spare tubes on Amazon. I have also used a pipe cleaner once the great stuff dries in the tube to clean it out.
As a caution a little bit goes a long way and it can exert a good of pressure while it's curing and damage flexible materials.
2008 GMC Sierra 3500 SLT DRW D/A 4x4 (Big All)
2006 Ford F350 PSD SRW King Ranch 4x4 (Henry) (Sold)
B&W Companion, 90 Aux Fuel Tank, Scan Gauge II, Curt f/m hitch, Swagman XC
2015 Forest River Sierra 360 PDEK
DW Diane, DS Michael, FB Draco and Sabian
jplante4
I've used that in various places, home and RV, to closed holes. In the RV, I used it to seal the hole where the water plumbing comes through the floor. Put some newspaper down on basement carpet else you'll never the the stuff out of the carpet. It does tend to go everywhere.
Like you I had a gap in the sheet metal under the shower. The problem was the the shower is over the wheel well and the road grime and water made a nice mess. I screwed down the sheet metal and then used great stuff to fill in the gap on top.
You can get a can with a trigger type applicator tube which does stop, but to be honest if you don't use the whole can, just throw it out. You'll never be able to clean the stuff out of the tube so you can use it again.
Jerry & Jeanne
1996 Safari Sahara 3530 - 'White Tiger'
CAT 3126/Allison 6 speed/Magnum Chassis
2014 Equinox AWD / Blue Ox
