mfinnerty
Nov 03, 2020Explorer
Not if you are careful removing the old seal and installing the new seal. I yank the old seal out using a needle nose pliers and then very carefully insert the new seal being sure to get the seal in the slot around the rim of the opening. You'll have to hold the blade back using the foot pedal while doing this. pay attention to the orientation of the old seal so you get the new seal in the same way.
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,190 PostsLatest Activity: Mar 30, 2026
