stationaryfullt
Aug 08, 2014Explorer
Re-torquing bolts on a weight distributing hitch
I need to adjust the angle of the platform on my weight distributing hitch to get more spring tension out of the bars. The bolts that hold the platform to the shank call for something around 400 ft/lbs of torque (don't remember the exact spec, but it's on the instructions at home). They also use lock washers. Lock washers are usually one-time use and I would think a bolt torqued that tight would have stretched some.
Do I have to replace the bolt and washer to adjust the hitch platform? I don't mind doing it, but it's not listed in the documentation that I can see. I also can't see the manufacturer requiring it when the average hitch setup takes more than one try to get the adjustment right.
