kampersTnS's avatar
kampersTnS
Refridgerator
After a power outage for 5 days, our fridge will not work. It's flashing lp/ac/au but will not turn on. When we hit temp set button it just counts down and continues. Please advise. Thank you!
  • wa8yxm's avatar
    wa8yxm
    Try this, Turn it off, in fact if you can find the fuse pull it, Plug in and charge the batteries for at least 2 hours. Restore fuse and try again.
  • Firdge pulls aobut an amp while it's actually cooling and runs roughly half the time. So your batteries are more than likely dead.
  • bukhrn's avatar
    bukhrn
    Perhaps your gauge is wrong, & you're out of propane?
  • I would assume your 12V battery is dead. It is needed to run the refrigerator even when you are using propane.
  • Chances are your camper battery is drained dead also, after 5 days of power outage.Your battery may need to be charged up a while before the refrigerator operates correctly. Although it may run on gas or electric, it still takes the battery to control it.
    Try turning it off completely, waiting for a short while, and try turning it on again.
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,115 PostsLatest Activity: Mar 04, 2025
