- Y-GuyModeratorFifty4F100 this is a discussion forum. Forums are not going to always track 100% on topic. Clearly the answers here are not what you are seeking since you only wanted to hear from a very small audience that has actually had a problem to your specific question. With that I'm going to close this thread down. You might want to better understand the term 'Karen' and how it doesn't apply in this case.
Closed. - JRscoobyExplorer II
Fifty4F100 wrote:
Why do I keep getting all the “Karen’s” commenting when I specifically asked a reasonable question?! I had to get a moderator involved the last time I posted.
Just exactly what "Karen's" comments are putting your panties in a bunch?
Fact is most manual transmissions do not lube themselves as well when the input shaft is not spinning. It might be the height of input/output shaft, but most I have looked at those 2 have the same centerline. As a trumpism, I would say it has to do with the angle of gears, do they shove lube towards the bearings or away.
I think you will find few who tow when the manufacture says don't, because we trust some science - magicbusExplorer IISo I guess everyone should have said no and you would be happy. Instead you feel the need to toss insults.
When no transfer case is involved It all depends on the design of the transmission. If the output shaft is on the bottom the transmission will be okay because it is lubricated by being bathed in oil. If the output is on top and the input on the bottom you stand a chance of damage because the lower input shaft is not turning and providing oil on the output shaft which is being driven by the wheels.
In the end it does not matter if someone reported they personally had a manual transmission fail while towing because it depends on the design and therefore the make and model of the vehicle being towed.
Dave - Fifty4F100ExplorerWhy do I keep getting all the “Karen’s” commenting when I specifically asked a reasonable question?! I had to get a moderator involved the last time I posted.
- ferndaleflyerExplorer IIIIn 1966 I towed a 4 speed 1959 El Camino from Mesa, Arizona to Washington, DC behind a 66 T Bird. Both ran for years until I got rid of them.
- JRscoobyExplorer IINot RV, but back in '70s, when driving a tow truck there where some that we would only pull as far as the shoulder before we pulled axle or driveshaft.
I towed my old "3 on the tree" Ford for about 300 miles 4 down. After that it made noise in 2nd gear.
I know several guys that would tow their VW based dune buggies. 3 of them towed about 500 miles in convoy. 1 would not shift when got home. - BumpyroadExplorer
Fifty4F100 wrote:
Horsedoc wrote:
Why don't you explain the reason for this question?
Information
I get this nagging feeling that you are planning on 4 down towing a vehicle not "approved" for this use and if nobody comes on here saying that they towed their 1958 hupmobile 4 down and it blew up, take that as making it OK to do so.
but then you won't say what/why you want this information anyway.
bumpy - Fifty4F100Explorer
Information - Fifty4F100Explorer
Bumpyroad wrote:
in addition to "ruined", you should include reducing the life expectancy of the transmission which may not show up and be experienced until the vehicle goes thru several different owners.
bumpy
That’s too hard to qualify. There’s way too much that can contribute to transmission life. And if you’re buying used, the previous owners treatment/maintenance is involved.
I’m wanting to know if someone had a good running vehicle that wouldn’t run after a tow. - HorsedocExplorer IIWhy don't you explain the reason for this question?
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,117 PostsLatest Activity: Mar 12, 2025
