- Ed_GeeExplorer IIThat does look intriguing... I wonder how well it would hold up over years. I already have a Teknor Apex Zero-G hose . It is similar and made in America. I just love it...very light and compacts easily for storage.
- nickthehunterNomad IIDon’t know, ain’t worth my time looking it up to see what your talking about; if you’d have provided a link, maybe.
- Earlier hoses like this Silver Bullet Hose had weak connections at the bib ends. Silver Bullet at house works good, but I do release pressure when not in use.
- Boon_DockerExplorer III
Here You Go - haste_makerExplorer II
Thanks for this info...I looked up the link & I like this much better that the Silver Bullet Hose... - Grit_dogNavigatorLol.
But wait, there’s more!… - haste_makerExplorer II
I sure hope you have the time to look at the link, maybe.
https://www.silverbulletoffer.com/?mid=10574452&vendor=google&campaignid=1751156552&adgroupid=77017573188&targetid=kwd-669835652639&mt=b&network=g&device=c&adid=347596668394&keyword=silver%20hose&adtype=&merchantid=&productchannel=&productid=&placement=&gclid=CjwKCAjw9e6SBhB2EiwA5myr9vEePC1JN9FIfuXbwFHSLIiUPgxSBABvZM5MnRW2-XDX902FD0CfSxoCb-gQAvD_BwE
You may have to copy & paste. - wa8yxmExplorer IIIOk for things like washing the RV and other uses where it is NOT connected to the RV but not recommended for use as an RV fresh water supply hose.
WHY: Heaven forbid the park loses pressure (happens a lot) the hose will try to retract down to "storage" size and I've heard (Never seen but never gave my expanding hose the chance) that they can pull the water inlet off the Rig.
Knowing (As I do having worked on mine) how they are attached.. I suspect... it can. - markchengrExplorer IIManufacturer says do not leave it pressurized except when using it so not recommended for continuous hookup. I use one for filling the water tank and for washing down. It's important to note on the label that it is approved for potable water, some of them are not.
- wildtoadExplorer IIMost of these type hoses tend to restrict water flow as they need the pressure to expand the hose. I have one in the RV and one at home. Useful for casual use, but if you want a lot of flow, not so good.
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,102 PostsLatest Activity: Jan 18, 2025
