ajriding wrote:
So, using the Dicor you covered 6 inches, the same girth as you did with flexseal?
Did you dicore over the screws too?
I can't imagine Dicore Lap sealant not working. I suspect user error, so curious what your method was.
Dicore is good for RVs since it is a good idea to re-do this every few years anyway. Dicore is easy to remove and re-apply.
Sounds like by a few years the flexseal will deteriorate so can be cleaned away with a small wisk broom at least.
I covered the area thoroughly I know what I am doing, I spent 50 years in commercial construction.
The issue with the Dicor for this job in my opinion is the small hairline cracks and fissures that happen after application and I doesn't "flow" into those small spaces like a liquid.
Thanks for your upbeat post.
