rwgeiser
Apr 28, 2013Explorer
Looks like the bearing races can be removed and the spindle cleaned up. Clean up the seal boss area and install a speedy sleeve from most any auto parts store. They can tell you which sleeve is needed by the seal diameter of the new seal.
The four bolts that were pointed out in the above post hold the brake backing plate on.
About RV Tips & Tricks
Looking for advice before your next adventure? Look no further.25,104 PostsLatest Activity: Jan 24, 2025
