ian_c
Dec 21, 2015Explorer
Suburban SW10 DE water heater doesn't!
I just can’t figure this out. Our Suburban SW10 DE water heater doesn’t heat. It was functioning normally before it failed. It works well on the LP side but not with electric. I have checked and replaced a number of things.
The breaker works. The inside electric switch works. The on/off rocker switch on the heater panel works. The thermal switch has not been tripped.
I replaced the heater element with a Suburban part thinking that was the culprit. A volt-ohm meter reads that there is power going to the heater element when both switches are turned on.
Yet it does not heat the water. Any suggestions would be gratefully appreciated.
Many thanks!
Ian
Many thanks!
Ian
